Burnham Domestic water coil gasket replacement
rickwilt
Member Posts: 1
in Oil Heating
I am pretty handy and would like to tackle the replacement of the heater cover plate gasket
I assume you have to drain the boiler, if this is correct I will have to drain the whole system as the valves are old and I know will leak
Thanks for any reply
If it was an RS series, I say go for it. If it is a "V" series, wait for warm weather, and hire someone to do it0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
