Ex LARGE Simple TStat??
Patchogue Phil_2
Member Posts: 304
Need to find my 78 yo Mom a simple, dial analog, non digital low volt thermostat for heat. She doesn't see up close very well even with glassed. LCD screen is a no-no.
Honeywell has one ...T87N1026Steve Minnich0
I found that too. The thermometer reading is still small.0
This is the best I've got.
http://www.amazon.com/gp/product/B000GGPMO2/ref=pd_lpo_sbs_dp_ss_1?pf_rd_p=1944687682&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B000TD1JVC&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1R564QW4T6HE97K9PEVF
This also looks like a possibility, but I don't know how well it works.
http://www.amazon.com/Lux-TX9600TS-Universal-Programmable-Thermostat/dp/B0044UYVFW/ref=pd_sim_sbs_hi_1?ie=UTF8&refRID=095D2SDBAYT4BZJ5647R
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
http://www.supplyhouse.com/Lux-PSD010BF-Digital-2-Wire-Heat-Only-Thermostat-with-Fan
This one w/ a back light would help.
Simple controls.
That will be tough with no lcd.0
Try maxi-aids0
The ones with the blue displays might be easier on her eyes, but any digital unit can be inadvertently set wrong. The beauty of the old round Honeywell's is they were pretty much bulletproof and most folks were used to them.
3PSI gauge0 -
Maxi aids has a magnifier that will fit the t 87 or the Honeywell @Stephen Minnich suggested0
What about using that Honeywell and also installing a large easy to read digital thermometer next to it?Patchogue Phil said:I found that too. The thermometer reading is still small.
Should solve both problems.
Honeywell T87N1026
And this hung right next to i.t
http://www.amazon.com/Extech-445703-Big-Digit-Hygro-Thermometer/dp/B00069ECFY/ref=pd_sim_hi_2?ie=UTF8&refRID=0T76RN6NPP9PSE4EAGR8
Or this one
http://www.amazon.com/La-Crosse-Technology-302-604S-Thermometer/dp/B004QM97CU/ref=pd_sim_hi_5?ie=UTF8&refRID=0X753PYX4BHXT86NQT9ZSingle pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
Good idea Chris. I had put a round analog thermometer on the wall, meant for outdoors so it has large numbers. For that digital thermometer, I'd have to put black tape over the humidity reading so Mom doesn't get freaked out!!
As an aside, my brother discovered Mom had torqued the existing round dial tstat so much that it was no longer level. Setting the dial to max range HIGH only got the house to 68°F!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
