Looking for wiring diagram
j_trayser
Member Posts: 3
in Gas Heating
I have a furnace problem. My repairman, a friend who is not computer savvy has asked me to go online and try to get a wiring diagram for a Peerless gas boiler. It is a G-561sw. He replaced the main gas valve but needs the wiring diagram showing how to wire it to the low cut-off and high cut-off controls. Have searched the net for this info, but came up short. I would certainly appreciate any reply or help on this matter....and so will my repairman. If there is any other information you may need, please let me know.
Thanks
John
Thanks
John
is it anything like this?
http://www.peerlessboilers.com/Resources/Literature/TechnicalInformation/IOMManuals/tabid/86/Default.aspx0 -
Have been there before Nicholas. I don't know which IO&M the g-561 falls into, if any. These all seem like newer model versions based on the dates, unless I'm wrong.
Give me the numbers of the controls and make and I will tell him how to wire it.0
Tim...the make is Honeywell, the numbers are:
8802
PA404A 1009 2 (SA)
Two controls: one low cut-off, one high cut-off, both the same numbers and make. Numbers here as seen on sides of both controls.0
