Why might my heat be only cutting on at night?
Deeno
Member Posts: 1
in Gas Heating
I have it set to 68 for morning, and 70 for day, evening and night on the thermostat, however it has been running at a frigid 50 degrees until night and then it finally cuts on at 9 and gets up to 70. Going on day 3 of this and its snowing tomorrow.
A little more information might help. What kind of thermostat? what kind of heating system? Could be a bad thermostat, but can't say with 100% certainty with your description. Is this a programmable thermostat? Was it working fine 4 days ago?0
Have you changed the batteries?
Is it an analog thermostat and is 12 hours off?
If it is a analog thermostat, has one of the setting pins fallen off?0 -
Is this an apartment, or your home?0
Just going by your picture you don't need any heat at night. Yowsa!-3
If the heat only seems to come on at the same time every night, I would lean towards the t-stat not programed correctly. If you can get me some numbers on your particular model and we'll see what we can do.
Unclejohn,.....the woman needs help, try to stick to the topic. The Idea is to make people comfortable in coming to this site with questions, not the other way around.
Mike T.2 -
Depnding on the thermostat model there should be an over ride feature until you get things figured out. As stated above the thermostats make, and model, or picture will help us find instructions on how to program it in case you dont have them.
- 125 Chimneys & Flues
- 121 Geothermal
- 396 Solar
- 19 Recall Announcements
