What Type of 1 Pipe system do we have
JohnWest
Member Posts: 1
We have a 1917 Courthouse with 2 Clearfire Steam Boilers in the Basement.
The condensate Returns from the Radiators to a Holding tank in the Basement.
Would this be a wet Return?
what returns are return lines below the water level of the boiler usually there are exceptions when false water lines need to be used due to a change in water line with the new boilerCost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 120 Geothermal
