Looking for suggestions for a simple radiant system
DanSadler
Member Posts: 4
Hi folks.
I'm a general contractor building a small place for myself and am, for the first time, installing hydronic radiant. I've been browsing the wall for a couple years as I've been planning this project.
I'm getting ready to talk with a radiant designer and wanted to ask here for some suggestions first.
The home is in snow country, the Sierras in Northern Ca.
Approx 1150 sf ground floor and 400 upstairs.
I plan to use Warmboard for both floors.
I'm was thinking that each floor would be a zone. Guessing that each loop could be fine tuned at the manifold.
Should I consider just one zone?
Was interested in a combination heater/ boiler. Any suggestions? Condensing?
Any general suggestions?
I'm hoping to have a system that's simple and efficient. Sound doable?
Any input/ suggestions appreciated.
Thanks, Dan
Thanks, Dan
Bedrooms upstairs? A,condensing combi boiler yes!
How are them floor treatments through out consistent, or wide range. Might dictate different supply water temps.0 -
Planning stone tile throughout.
Upstairs is a master suite0 -
If,you like,comtrol in sleeping areas zone them that's,about it. Not a big house well I don't mean that negatively I just mean don't get zone happy. Just make sure,the smallest zone is not less than the boilers min. Modulation. Otherwise short cycling becomes an issue. Have you done a room by room heatloss first step.0
No I haven't.
Am planning to over insulate. Need to get those values nailed down.
Any suggestions for a radiant designer?0 -
House that small and tight may not even need a dedicated space heating boiler . Could do away with any short cycle issues and extra cost with a Phoenix water heater , FPHX and 2 ECM circs or as suggested above a nice combi , the kind with a small hot water tank though , not a tankless type .What is available for fuel up there ? Did you have any specific equipment in mind ?
Insulate how you want , just make sure not to create any moisture issues in the walls and pay close attention to getting air sealing proper . Are you above or below 6,000 feet , Eastern or Western side ? Basement or crawlspace ?You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Plenty of great radiant and solar guys in CA. Where bouts are you located, I can give you some suggestionsBob "hot rod" Rohr
Is this "small place" a Get-Away place that you will use sparingly, and not be living in 24/7 in the snow times?
If so, you might consider that your radiant can be a PITA with the long periods it takes radiant to warm up the space radiantly. Like days.
Hydronic radiant is a wonderful thing. Much better in the right application. If the reason you're building this place is to enjoy cold snow activities, and you might come in from the cold, Radiant can take a long time to warm up whereas LP gas wall heaters might be a far better choice.0 -
Ice ,
Warmboard is very responsive unlike mass systems and below subfloor stuff . the tubing is in contact with the finish floor and has a hefty aluminum surface that makes it not sucseptible to Days to heat up or even more than a few hours . It's response time is pretty impressive .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
That may be.
When my wife is cold, she wants heat YESTERDAY. Not in a few hours.
And the cats lay in the sun for extra warmth. The dogs did too. You don't have to take a cat for walks carrying a doggie poop bag. They poop in a box. Every few days, at your convenience, take the cat litter bag out to the trash.0 -
Get a new wife . Dogs are better than cats , Cats suck. Get rid of the cats , get a dog , get invisible fence , have enough property that you don't need a bag and clean the crap out of your yard every couple of days .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38331 -
It took her over 51 years to train me.Rich said:Get a new wife . Dogs are better than cats , Cats suck. Get rid of the cats , get a dog , get invisible fence , have enough property that you don't need a bag and clean the crap out of your yard every couple of days .
Dogs aren't better than cats. Like I said. You don't have to walk a cat. I've had lots of dogs.
I live in a Condo. If you want to walk your dog in the Common Areas, you need a doggie baggie for the poop. If you take Rover to the dog park, you still a doggie baggie. No one takes Muffie the Cat to a dog park.
Invisible fence doesn't work on all dogs. It doesn't work on cats.
Its a lot quicker and easier to clean a cat box every few days that pick up doggie doo in the yard.
I'm well practiced in picking up animal waste. My wife's horse (and most horses) poop 50# pounds of horse litter per day. Not including stall bedding.
Horses, dogs and cats are far better than children. They don't get knocked up, or they don't knock others up, they don't sneak out and meet others to drink and do other things, and when you put them to bed, they stay there. And they don't steal your cars and crack them up at night when they sneak out.
With cats, if you go away, all you need is to have someone drop by occasionally and refill the cat feeder and water'er. The litter box if it is for a long time. With dogs, you have to pay to board them or have someone come a few times a day to walk them with doggie doo bags.
Once a dog learns to run through an invisible fence, you can never ever again contain them again. Like Jack Russell's.
I'm trying to design the house with different options in mind.
Seems that with Warmboard and today's web enabled thermostats, one could turn the heat up on their way up to the ski cabin and it would be comfortable by the time they get there. People tend to leave the thermostats at 50 when they're away, so the rise isn't all that much anyway.
Home is at Donner Lake, near Lake Tahoe.0 -
Donner gets COLD sometimes. If you're well insulated and don't have any real mass in the emitter system other than the Warmboard, it should work OK.
15+°F is a deep setback, BTW. You may need to wake the system up before you leave the SFBA in order for it to hit its marks.0 -
If it is a new house use gypcrete rather then warm board you can balance your heat loops much better, Donner area you can have your house set up by a few different companies. Zoning is simple most of the time Living, master, guest beds, master bath and Garage is about all that's needed. Depending on your layout.-1
- 87.2K THE MAIN WALL
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 75 Pipe Deterioration
- 6.4K Radiant Heating
- 15.6K Strictly Steam
