Cracked radiator
JohnW2
Member Posts: 21
I had a radiator that was making a strange whining sound, but it wasn't coming from the vent. I noticed that the floor was slightly damp below the radiator. After feeling around on the radiator, I found a point near the middle top where some old paint was feeling off, and it was slightly damp. I can't really see the crack/hole, but I can feel where water is leaking out. Is there any way to fix a cracked radiator, or is it going to need to be replaced? And what are my options if it needs replacing? New? Used? What is the best way to proceed? I'm guessing it's going to cost me a fortune.
Some people have had luck using JB weld type products to make repairs, but it depends how bad it is. I personally have not done it, but others here have with some success. The other option of course is replacement. This depends upon your options. I know in my area there are several salvage companies that sell used radiators that have been pressure tested and warrantied for 1 year. They typically need painted, but the prices are reasonable (we do not discuss pricing here). I am assuming this is a steam radiator by what you said?0
Yes, one pipe steam system.0
Is it leaking around one of the push nipples between the radiator secctions? Most radiators have rods (usually 2 near the top and two near the bottom) that run through the entire radiator to hold the sections together. Is there any possibility that you can tighten those, at the top, up a bit? They may have stretched a bit over the years from expansion/contraction.0
No, unfortunately it's in one of the section tubes itself, a few inches down from the top.0
Try the JB weld. Just be sure to clean the area really well and turn the radiator off for a few hours when you do the repair to allow the epoxy to cure. If you can find the crack, try to push the JB weld into it as much as possible.0
I had a radiator (single pipe steam) crack on me around 15 years ago in the area of the vent hole, I cleaned all the paint off and got it down to bare metal, slapped on some JB weld and it has been fine ever since0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 983 Plumbing
- 389 Solar
