B&G Flo control valve
BillEllen
Member Posts: 2
in Gas Heating
I have a right angle Bell & Gossett flo control valve (marked 2”, FA6) in my heating system. I don't think they make this in 2” anymore. It drips from the stem.
Do I need to drain the system in order to replace the packing or will just shutting off the water supply be enough?
My sister's house has the same SINGLE zone heating system with no flo control valve. Do I really need this thing?
Thanks
BillEllen
Thanks
BillEllen
You most likely need it unless you have all zone valves.
You can usually re-pack them if you drop the pressure. You don't usually have to drain the system.0 -
I agree icesailor but would hate to have them damage anything after the fact, and panic if not sure. If only the gauge is 1 or 2 psi off and the nice leather couch they were going to give their sister was ruined.....oh boy,......lol. I hope that was at least a little funny.......
Peace Mike T.
Depends how fast you can do a repack.0
10/4 Gordy.......:-)0
Well, I always found that the air vents left tight, the fill valve off, and the drain hose outside, once you got a vacuum, and the hose slowed to a trickle, you were finest kind.
I usually worked at getting the packing nut loose long before I ever got out the drain hose. And getting that lever off the top, which usually didn't come off. But you had to get the stem all the way up before you even thought about the hose.
I found later in life, that a long piece of Teflon tape, spun into a long fat thread, was the best packing material around. You could wind multiple wraps around the shaft and still get the nut to catch the threads. Put some Super-Lube synthetic grease on it, crank it down, put more on if it will take it, and the world is a happier place. Especially if you don't have to change the valve.1 -
We can assume you've tried tightening the packing nut?0
