American Standard Arcoleader A1 J4 Boiler
snoho
snoho Member Posts: 1
Expansion tank is waterlogged and has a "Corky" fast drain plug with no instructions on how to use? Any help would be appreciated.
  • unclejohn
    unclejohn Member Posts: 1,833
    Keep opening valves until water comes out.
  • billtwocase
    billtwocase Member Posts: 2,384
    Is there a stop and wasted valve used as an isolation to the boiler? Remove the waste cap to get air into tank if set up this way
  • wcs5050
    wcs5050 Member Posts: 148
    Attach air chuck assembly to tank drain and drive the water out of the boiler drain (if there is isolation) Careful not to make air balloon of boiler.
  • billtwocase
    Wow. That is overkill way to drain the tank
    icesailor
