American Standard Arcoleader A1 J4 Boiler
snoho
Member Posts: 1
Expansion tank is waterlogged and has a "Corky" fast drain plug with no instructions on how to use? Any help would be appreciated.
Keep opening valves until water comes out.0
Is there a stop and wasted valve used as an isolation to the boiler? Remove the waste cap to get air into tank if set up this way0
Attach air chuck assembly to tank drain and drive the water out of the boiler drain (if there is isolation) Careful not to make air balloon of boiler.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
