Problem with Rinnai model 2520 loosing hot water
hopewkis
hopewkis Member Posts: 3
We have a Rinnai he model 2520 and it's about 9yrs old and we keep having problems with the hot water will turn cold . You can be taking a shower and all the sudden you have no hot water what could be some of the problems that could be going wrong with it . We have cleandedbthe senders off but icould it have something to do with the water flow we don't have very good water pressure and could that cause it any suggestions would be appreciated
  • Snowmelt
    Snowmelt Member Posts: 1,454
    Dirty burner, did u check pressure coming in home? Do you see any water at bottom of burner tray?
  • hopewkis
    Can you clean the burner
  • hopewkis
    Plus it doesn't do it all the time we have 7 inc going into the house and we have cleaned the igniters off
