Has anyone ever seen this?
Tinman
Tinman Member Posts: 2,808
I pulled this out of a built-in casting/pump flange on a very old American Standard boiler? The boiler side pump flange was actually cast into the section. But...I've never seen this brass fitting inside the pump outlet flange? Does anyone know if this was actually an American Standard part? It was a perfect fit. Or, some after market remedy of some sort?
Steve Minnich
  • Tinman
    It puzzles me too. I can't figure out why they wanted to restrict flow. Typical Series 100 that was on there. I was betting on Dan, Hot Rod, Ice Sailer, Gordy, or Ironman to have the answer.
    Steve Minnich
  • Tinman
    Sailor***
    Steve Minnich
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,853
    It's a Turbo Encabulator.
    https://www.youtube.com/watch?v=rLDgQg6bq7o
    ME
    KC_JonesRobert O'Connor_12
    hot_rod Member Posts: 22,217
    some sort of diffuser mechanism. maybe to encourage flow across the sections instead of a straight path?
  • Harvey Ramer
    Harvey Ramer Member Posts: 2,239
    I'm going to venture a guess. Depending on the location of the flange casting, that piece may have been used to disperse the water as it entered the boiler. To prevent a current from forming through one section and not enough flow through the other sections.
    Do you have pics of the casting?
  • Tinman
    Thanks HR
    Harvey, I do not.
    Mark, I was thinking the same thing.
    Steve Minnich
  • Mark Eatherton
    I agree with Harv and HR. Those old Am Stan boilers had extremely large, open water ways on them, and water being like my ex brother in law (wet lazy and stupid) likes to follow the path of least resistance. Having the baffle immediately inside the boiler causes a turbulence that breaks up a straight shot through the sections resulting in leaving hot spots and wasted energy.
    I am thinking that if you did a combustion analysis with the baffle in, and then removed the baffle and retested, you'd see a significantly higher flue gas temperature due to this syndrome.
    Frank Wilsey (Steamhead) has an article in the archives about sizing a pump for older gravity to forced circulation systems. It follows the same theory of being able to run water through these old low pressure drop boilers so fast that they don't get a chance to get their sections scrubbed by the moving water.
    Or, it could be a turbo encabulator :-)
    I've seen something similar in copper tube boilers, but it was made of a spun fiberglass insert. Its function was to negate hydraulic erosion corrosion on the return side of the heat exchanger. It had rifling inside to cause the water to swirl as it went down the tube, thereby scrubbing the heat exchange surface, thereby increasing the Reynolds numbers and avoiding reverse turbo encabulation… (all but the encabulation comment is true, honestly.) Seriously :-)
  • icesailor
    icesailor Member Posts: 7,265
    FWIW, I too think it is some form of a diffuser to diffuse flowing water in the boiler.
    I had a customer with a really old house. That had been moved and re-assembled hundreds of years before, on top of the existing buried foundation of a prior house. Sometime in the 1930's to the 1950's. they put heat in. In the back of the house off the kitchen was a LOOOOOONG radiator. Well over 30 sections with a leg section in the middle. It was fed on one end. You couldn't get to the other end because of a old foundation below. The radiator never heated beyond the first three sections.
    I removed the radiator, took a piece of 3/4" copper tube that was 3/4's of the length of the radiator, drilled some 1/4" holes along the length, left the end open and put it inside the top nipple passage. I turned it back on and it worked like a charm. The owner was thrilled. It now worked. Getting the hot water to the far end of the radiator got hot water along a longer section of the radiator and eliminated the dead spot because of the length.
    We didn't know it specifically, but old boilers we erected had the return in the back with two returns and one larger supply outlet. We used to add a recirc line to help with internal mixing in the boiler. I installed a few real ship box 4 section dry base boilers in the mid 1970's. The Tankless was in the back section but all the boiler water went through the front section. I installed a 6 section. The tankless wouldn't get hot because the circulation to the back of the boiler was so bad, the hot water by-passed the back. Bad internal circulation.
  • RobG
    RobG Member Posts: 1,850
    Were you replacing the boiler? If not did you put it back in?
