Smoke
smartin1019
in Oil Heating
Was down in the basement when the oil burner fired up. Noticed a small puff of smoke came out where the main pipe comes out the top. Is this a sign of trouble?
Sometimes.
Not usually catastrophic.
pics would help here. I wouldn't go out on a limb and say no problem. Could be delayed ignition, breech draft issue, flue collector issue, etc. Be safe, get it looked at0
Thanks when you say delayed ignition when I was in the basement I heard the burner kick on but it took at least 2 or 3 seconds before it actually fired. Think it may just be time for a new burner.0
The burner you have may just need to be tuned up, a good tech will figure out whats wrong and how to fix it. It might be best to put a new oil burner on the boiler but don't assume that without knowing why.
3PSI gauge0 -
Don't throw the baby out with the bath water. Electrodes are cheaper than burners. What do you have for a unit and burner? Any pics?0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
