Cold radiator and cold inlet pipe
JonC
Member Posts: 26
Hi - as I'm working on my slope problem in the returns, I'm also fixing some cold radiators. I fixed one with a new trap but this fix didn't work on the other. I noticed that the inlet pipe (steam) is not getting hot. Any ideas? The radiator has a thermostatic valve (actuator off at the moment as I can't find a replacement) that I assume is open. Two pipe radiator with boiler in basement and problem boiler on landing of stairs - two storey house..
Pic attached.
Thanks
Also -any idea where to get a replacement actuator for a Honeywell T5038A1008?
Pic attached.
Thanks
How close to the radiator does the pipe get hot? Trace back until you find out where the steam is stopping...Br. Jamie, osb
Impoosible to trace it back - it's cold at least 5 inches from the valve. I can see the steam pipe entering from above, at a 45 degree angle, which doesn't seem right. It heads in the direction of the upstairs bedroom - about 8 ft above. Maybe I'll just let this one not work.0
I suspect the Tvalve may be broken in the "off" position, sending all the heat to the upper bedroom. You may be able to get internal orifices to do a similar job.Two-pipe Trane vaporvacuum system; 1466 edr
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF0
