Busy!
DanHolohan
Member, Moderator, Administrator Posts: 16,539
During the past week, 210,060 people stopped by here and explored 627,769 pages of this site. 69.7% of those people were here for the first time. Hello!
Retired and loving it.
There is definitely something in the air. My phone is ringing so much I can't get my work done. It's a paradox.0
Good days ahead for sure!Retired and loving it.0
That thing in the air might abnormally low temps across much of the country.0
I'd say Mr. Nadle is correct. -16 here this morning. Chilly! My wife will be driving the kids the 2 miles to school this morning. Too cold to take chances. Brrrrr.
If not for this site, I would've had to call a pro for a dumb iced over intake vent last weekend...hopefully others find the same excellent help!Ford Master Technician, "Tinkerer of Terror"
Police & Fire Equipment Lead Mechanic, NW WI
Lover of Old Homes & Gravity Hot Water Systems0 -
In my useless and minority opinion, if you have a Mod-Con boiler and the intake is freezing/icing up, you have cross contamination and are sucking exhaust into the intake.
If it is -16F outside, there is little to no available moisture in -16 degree air but the exhaust air is saturated to the point that it makes clouds or fog. The surface of the intake at the outside of the building is -16 degrees. Water vapor may not freeze until it is as low as -40. The vapor only needs a frozen surface that is at least 32 degrees to freeze on. You need more separation between the exhaust and the intake. For your location, they need to be a minimum of 30" from the ground. Probably more.
If it is making up ice on the intake and blocking it when it is that cold, I would consider taking the boiler cover odd until it warms up. It could get messy.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
