Could antler setup with 3 goetob #1 cause water hammer on startup?
rrwitherspoon
Member Posts: 104
Increased main venting with 3 x gorton #1 air eliminator now with rhyrhmic water hammer on startup
Can you pinpoint the area of piping responsible? Check the pitch of that line frome header to return, as there may be a low spot, trapping water.--NBC0
hopefully you are moving water that will not return0
