Cool Rads, check these out
GW
GW Member Posts: 4,943
We just pulled some of these out of a home, in Amherst Mass
Gary Wilson
Wilson Services, Inc
Northampton, MA
gary@wilsonph.com
    Steamhead Member Posts: 17,737
    The problem is, you removed them from the house.
    Consulting
  • GW
    I'm sad to say the system had already been abused, a 1.5 gph Peerless with one 2" riser and header.
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • GW
    Old to new in one week. Notice the recommended boiler piping, that's my marking (not the guy who installed the Peerless)
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
    kcopp
  • ChrisJ
    ChrisJ Member Posts: 16,609
    So, because it needed a new boiler you ripped out all of the radiation and piping?
    Isn't that like throwing a car out because it needs an oil change? :o
  • GW
    Yes, that's what I was thinking
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • ChrisJ
    Oh,
    So you didn't convert this, someone else did and then you came in to pull the radiators out?
  • Steve Minnich
    Steve Minnich Member Posts: 2,868
    Cool rads, nice job! What did you use for the new heat emitters? Home-runned, just running on outdoor reset?
    Steve Minnich
  • JStar
    JStar Member Posts: 2,752
    Where are these radiators right now? They better not be in a junkyard.
  • GW
    Chris, no, we took out the old and installed the new system.
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • GW
    Stephen, all new rads 33 series everywhere except for two 22s in the two bathrooms. We use Hydronic Alternatives. Yes it's on full constant circulation with the FW200 control on the wall in the living room. Alpha pump is running about 6 or 7 gpm. 70,000 btu worth of rads. Yes all home runned.
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • ChrisJ
  • GW
    J, you can now breathe, they are in my basement. The HO grabbed 5 of the cast iron tops. We have all the rads and 3 of the matching tops. 3 of the 11 rads were basic.
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
    ChrisJ
  • BobC
    BobC Member Posts: 5,521
    They are a piece of history, I'm gad they found a new home - well done.
    Bob
    3PSI gauge
  • Snowmelt
    Snowmelt Member Posts: 1,428
    What's up with the air seperator on the bottom teed off. And the vacuum break by the water heater?
  • JStar
    Well, be prepared for a slew of negative comments. If I were you, I would have chosen to omit the part about removing the steam system. Things will get ugly around here because of it.
  • GW
    Snowmelt, where would you like it to be intalled? Please give reasons.
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • GW
    J, I guess you're right. It started out being a topic of cool rads
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • ChrisJ
    That were torn out for no reason and replaced with uncool rads.
  • KC_Jones
    KC_Jones Member Posts: 5,883
    2014 Weil Mclain EG-40
    GordyJudySweetland
  • Fred
    Fred Member Posts: 8,542
    So Sad
  • vaporvac
    vaporvac Member Posts: 1,520
    One of the sadder posts as they were made in the same town as the house. I could say a lot of things, but sad is what comes to mind. I don't understand why they couldn't be used in the current system. Sometimes homeowners just need educating. At the least they should stay with the house as the NEXT homeowner may want to reinstall them. They'll probably be pulling out the old windows, putting up aluminum siding and ripping off the roof next after watching too much This Old House and HGTV. . I'll stop now, these are just my pet peeves.
    Colleen
  • kcopp
    kcopp Member Posts: 4,543
    I am willing to give Gary a break. He has plenty of times where he has installed steam stuff. Sometimes if you try to convince a customer to install steam and they have their minds made up to get rid of it you lose the sale totally.... Hey it could have been a Scorched dry air system that went in.....
    Gary How do you like the greenstar? I have a few in. A few 100 combi's, a 57 and a 151.
  • ChrisJ
    I'm kinda giving him a break because the work he did looks awesome.
    Still not happy about the conversion though.
  • GW
    Wow I didn't know people were so sensitve. This old system had been beat up, vapor lines hacked out, weird piping cobled together with copper out in the system. The home owner wanted hot water, we do hot water.
    Yes I do steam too, just little house stuff.
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • GW
    Here is our last little PEG 150 job. Please take me off your hit lists.
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
    kcopp
  • kcopp
    Got any Pix of the 33 series rads? ... they are pretty cool.
  • Fred
    OK, that one works!
  • GW
    Ckopp, I'm finally getting used to the FW200, I like how it can be installed on the boiler (demand circ) or on the wall (constant circ). I dig the pvc venting too. I've installed over 100 wall hung Vitos, I'm still waiting to hear about their 95% woes. Our state rolls out
    $1500 for a 95% $1000 for less than 95 (over 92 I guess). I like the internal pump, and the cheesy plastic puker (totally non old school buy it saves a few minutes). I've got about 15 or so installed, only two combis and the rest ZBRs.
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • hatchet
    hatchet Member Posts: 10
    feel like I just witnessed a death.
  • KC_Jones
    I have zero issue with you for taking it out, just upset to see another steam system go away. Good on you for saving what you could.
  • JudySweetland
    JudySweetland Member Posts: 120
    Install looks very neat and professional.
    GW
