Main Vent Gorton 1 vs Maid o Mist 1
STvex
Member Posts: 71
Is there any difference between Maid o Mist 1 versus Gorton 1 in terms of Quality and venting capacity? Both look almost identical.
http://www.supplyhouse.com/Jacobus-Maid-O-Mist-J1-1-3-4-x-1-2-Main-Vent-Valve-3563000-p
http://www.supplyhouse.com/Gorton-G14-Gorton-No-1-3-4-x-1-2-Air-Eliminator-Main-Vent-Valve-3522000-p
Thanks for the advice.
The capacity is the same, I use one of each on my main and have not had a problem in the two years they have been there.
3PSI gauge0 -
Thanks any chance the maid o mist has plastic in it0
The MOM has a removable orfice.0
IMO Maid O Mist are poorer quality. My buddy used them on his mains and both leak steam from the back seem.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0
- 50 Industry Classes
