Boiler issue
Builto
Member Posts: 1
Hey
I have a Burnham NG steam boiler Model PIN5SNI-ME2
Turn the thermostat, pilot goes on then sounds like it will kick on but i hear small single tick sound then shut off and goes on re start mode for five minutes and keep doing that over and over. Any ideas what is wrong?
Thank you
Thank you
If you download the instructions for your boiler from Burnham, there will be a diagnostics check list, to determine the problem.
It sounds like there may be a problem with the pilot light, or one of the safeties on the boiler.
You may need professional help with this. Use the find a contractor button here to find a competent steam pro.--NBC2
- 50 Industry Classes
