one pipe system
bubbad
Member Posts: 15
no insulation sorry,adding in couple weeks,i added varivalve adj.vents 5/16orifice max to each of 6 rads,system is very quiet,no banging,surging,vent noises,or gurgling in rads.I installed a peerless 63/64 boiler this fall,skimmed 3 times myself,appears to be doing well.i now know how important insulation is so it's my first priority,my supply lines are 1.25
to 2 rads off one side of header,the other side of header is 1.5" to farthest rad and 1" to closer rads,i'm attaching pics
do you guys still think I need main venting,i calculate my edr at 210 from hydronics chart,i can almost balance with these varivalves
heating is fast boiler run times 10/15min maybe,it hasn't been that cold yet,i just want this system as effiecient as possible,while still not trying to fix what ain't broke
thanks for the help,not to many steam guys around
Looks like a peerless steam boiler,if thats the case you have a great steam boiler….Cant really see much from the pics, step back and take a few more..of the entire boiler….One thing that concerns me is there is a lot of combustion venting going into that chimney….Two, concerns, and not with steam, make up air and chimney size…Only because I can’t see the whole set up…Most likely O K but from the pic it warrants the question.The lack of cast iron fittings tells me right off, maybe not a real steam guy did the install….Again thats just my opinion….
- 117 Geothermal
