Good hacksaw? What's your preference?
I use my Sawzall for most cutting, but there are a few times I wanted a good hand saw.
the high tension I get with my lenox frame and nice new lenox blades is so sweeeeeeet. It is often the little things. Ok to highjack this a little, what is the longest you had a blade in your hacksaw for? I just realized I went 2 years, not that I did not gather plenty of new blades, I just kept leaving the new blades in the shop.Cost is what you spend , value is what you get.
cell # 413-841-6726
Well, in all honesty, its the hacksaw with the newest new blade and hopefully the proper TPI for what I want to cut.
Seeing as how most places I needed to use a hack saw on, I couldn't fit the saw in, my Plumber's Sawzall was my saw of choice. I always keep a full selection of new and slightly worn blades.
"Plumber's Sawzall" defined as a reciprocating saw with the blade guard removed. Most quality plumbers can do finer finish work with a "Plumber's Sawzall" than some finish carpenters.0 -
I got one of those little Rigid one handed reciprocating saw for close quarters. The thing is even lit with three LEDs. It makes cutting out threads and spuds out of radiators into a walk in the park.Cost is what you spend , value is what you get.
cell # 413-841-6726
Back in 2012 I had some cash on hand from doing a side job and decided to go buy a 13A Milwaukee oribital sawzall.
Probably one of the smartest buys I've ever made. I think it was around $150.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
My big sawzall is a Sawzall by Milwaukee and always will be. I have three in the shop I need to repair, new triggers and brushes, that are each 25 years old.Cost is what you spend , value is what you get.
cell # 413-841-6726
Amazing what we tool weenies can find out there to spend our money on.0
What's a "tool weenie" ?
Someone that can't go into a tool store and not leave with a new tool they can't live without.
Like some Shopaholic women. They're like squirrels and nuts. You can never have enough nuts.0 -
Almost indestructible.Charlie from wmass said:My big sawzall is a Sawzall by Milwaukee and always will be. I have three in the shop I need to repair, new triggers and brushes, that are each 25 years old.
Hmm.
I just found out we have a used / antique tool store 2 blocks from our house. Went in there the other night and there were so many things I wanted.
There was a beautiful large (6"?) Columbian vise in there and a bunch of Ridgid pipe wrenches I'd love to have.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Had them, never again. lol I have a quick change in my new Milwaukee, hate it.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating1 -
They all break (so far.) Milwaukee, Porter Cable, and (most recently, the one that was supposed to not have that problem) the Bosch.0
I'm trying to remember the last time any brand needed an allen wrench to change a blade?Hatterasguy said:
http://ecx.images-amazon.com/images/I/31TKCjmRChL.jpg
That quick change blade holder which eliminates the allen wrench: PRICELESS
As far as I knew, all brands had quick change blade holders for what, 10+ years now? I know Bosch did when I worked for them back in 2003.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
To be fair, they were all subjected to years of demo work on reinforced concrete structures with cast iron pipe. Only the TigerClaw actually broke anything significant.0
To be accurate, there is only one Sawzall and it's made by Milwaukee. All others are just "reciprocating saws".Hatterasguy said:I had to do some concrete demolition with the steam boiler. It appears that the previous owner desired to build a mausoleum for the 1000 gallon oil tank and he encased it in 12" of concrete...........to be sure it wouldn't go for a walk overnight..............
So, there were some huge chunks that couldn't be moved without further fracturing.
I had the privilege of using a rotary hammer for the first time. Still difficult work but it could drill down though 12" of concrete in less than 30 seconds. Impressive.
I can't see how any Sawzall can survive in concrete............just brutal work.
When I worked for bosch I rebuilt and tested many many demo hammers and roto hammers.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I hate the quick change because doing the steam work I am often in the rusty dirty water. The quick change needs constant cleaning. The allen wrench is more reliable. also I never shoot a blade out with the allen wrench style up on the staging and have to climb back down and find the blade.Cost is what you spend , value is what you get.
cell # 413-841-6726
The concrete (stucco, many times) gets broken up with demo hammers and sledges. The recip saw is for cutting lath and rebar, but there is a lot of dust and debris involved, like bits of stucco stuck to metal lath.Hatterasguy said:I can't see how any Sawzall can survive in concrete............just brutal work.
We beat the snots out of some of our power tools and complain when they break down or wear out?0
When I fixed the steam pipe going up to the baby's room I crawled into the crawlspace, stuffed shrink rap into the runout to keep stuff from falling into it, at this point this was the 2nd time I was doing this as I found I had to remove more floor.
I crawl out, go up stairs, go to cut the hole and the blade falls out down into the crawlspace.
I was not impressed.
I think that was my fault more than the quickchange but it wouldn't have happened with the allen screw type/Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I use hand hack saws all the time in the shop for my copper art projects.
The newer aluminum high tension frames are light years ahead of the old steel frames. The blades actually last longer also as they don't wobble around with the higher tension.
I like the Stanley with the higher arch frame, but the Lennox works great also.
The Hackzall from Milwaukee is a nice tight quarter cordless, easier for small copper compared to sawzalls.Bob "hot rod" Rohr
Living the hydronic dream1
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 959 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
