Baxi HT380, servicing
GW
Member Posts: 4,964
in Gas Heating
gas guys, we have 5 Baxi HT380's we take care of. Does anyone have a trick to get a good reading on the expansion tank? I fear my basic pump with its basic gauge is good, but not great, One of the boiler we service upchucked its exp tank recently, so now it's on our minds. Thanks for any comments. Gary
Do you have isolation valves to remove the system from the equation? Drain valves?0
The best way we do it is close the valves at the boiler and drain the boiler by its low point drain and then check the PSI with no water in system. I know you do need to keep that EX tank in use because of the DHW side of the boiler.
Good luck.0 -
SWEI, just the factory valves, but draining isn't so much the issue (and filling), it's the tap for the exp tank is way up high, I am wondering what tricks may be out there to get an good reading on the psi. Thanks, gw0
SuperD, thanks, any hot tips to check and or add pressure? That schrader valve is way up high. Thanks, gw0
Well this should help...
http://www.grainger.com/product/CHERNE-INDUSTRIES-Extension-Hose-1VNH40 -
thank you both, I dig the 90 degree fitting. Merry Christmas and may no heating systems take a nap tonight.0
Thanks for the comments....does this newer site have a way to get an email notice if a reply comes in?0
Click on the star at the top right corner of the first post.0
Look for an RV type air pressure gauge. They are available with a rubber hose and read accurately down on low pressures.Bob "hot rod" Rohr
Living the hydronic dream0
- 109 Chimneys & Flues
- 971 Plumbing
- 386 Solar
- 17 Recall Announcements
