anti scalding mixing valve
Mark......You don't install the a thermostatic mixing valve for the "norm". You install for the one-in-a-million chance that someone with the flu, passes out while getting into the shower, for instance. If the person survives, it will change their life forever.0
There are legitimate concerns with regard to pushing water from the (cooled) hot pipe into the cold pipe. There are compelling arguments to the contrary. The practical concern is that you really do need to understand what codes apply in your jurisdiction.
I now believe that properly implemented tankless electric post heat actually works better than DHW recirc in a majority of residential and light commercial applications.0 -
In most areas all tub and shower valves are thermostatic mix valves, limiting the temp.delivered to the fixture….I prefer to keep hot and cold lines completley isolated, but thats just me...0
thank you all for your advice and thoughts0
As long as the mixing valve is ASSE-1017 approved it is fine to use at the indirect water heater. Caleffi, Honeywell, Watts....0
thanks rob0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
