Does air vent = air valve = air eliminator?
davidnyc
Member Posts: 9
Is there any technical difference between an air vent you put at the end of the main and an air valve you put on a radiator, other than the amount of air they are designed to vent (and possibly a different size threaded fitting)?
I only ask because companies like Gorton name them differently. In our system the two main vents are tapped 1/8". The Hoffman #41 that had been there for many years was clogged solid, we replaced with a Gorton D (much larger air opening, although less than a Gorton "air eliminator").
A Gorton D vents the same as a Gorton #1 main vent.davidnyc said:Is there any technical difference between an air vent you put at the end of the main and an air valve you put on a radiator, other than the amount of air they are designed to vent (and possibly a different size threaded fitting)?
Main vents typically have a 1/2" or 3/4" connection.
1/8" is usually a radiator vent.
Other than that I think they are the same internally, other than the amount of air they can vent.
You will probably need additionally venting than that Gorton D you installed unless you have a 10' long 1" main.1 -
As far as I know all Gorton's are called "Air Elminators".
As was said a Gorton D is the same as a Gorton 1 except for it's connection style.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
- 50 Industry Classes
