Do you need to install an expansion tank for my DHW?
maybemark
maybemark Member Posts: 1,131
I am reading the manuals for the Lochinvar whn and the squire tank, and in some of the plumbing schematic they only show one expansion tank for the system. When i read the squire it said you might need an expansion tank for the DHW tank.
How do you do it? And if you do it, i have a 40 gal tank, what size would i need?
  • Zman
    Zman Member Posts: 7,609
    Mark,
    You will need a small expansion tank if you have a check valve either at the meter or between the hot and cold side of your domestic water.
    Carl
    Albert Einstein
    maybemark
  • maybemark
    Carl
    thanks. I'm sorry about last week. I got out of hand, and i respected to hold off on questions until this week. I figured on not asking until I would hear from you.
    Thinking about it, i don't even have a meter, and there is no check valve at the moment between the hot and cold.
    Chicago is asking everyone that the city will instal meters, but I chose not to get one, and just have a flat rate
    It's nice to hear from you buddy, I really am sorry
    Mark
  • Gordy
    Gordy Member Posts: 9,546
    Like Carl said. The theory is that IF there is a back flow preventer at the meter the hot water expanding has no where to expand to but the house plumbing after the back flow preventer (check valve) . With out the check valve the expansion pressure would be able to transfer to the city supply piping.
    With out the x tank it can do damage to a tank water heater, and other components in the system. Just so you understand the reason Mark. It's all about heated water expanding, and needing a place to go just like a closed loop hot water heating system.
  • Gordy
    Tank size for water heater LET 2 for Potable water.
  • maybemark
    Gordy
    thanks teacher
    Mark
  • maybemark
    what does LET stand for? I imagine the 2 is 2 gallons
  • Gordy
    edited December 2014
    Just a 2 gal potable x tank is all need be. Tank psi set to city pressure. Fred should know.
  • maybemark
    thanks
  • RobG
    RobG Member Posts: 1,843
    You could also use a Watts Governor 80 on your toilet. It will discharge any overpressure into your sewer in the case of expansion.
    http://www.watts.com/pages/_products_details.asp?pid=7237
  • icesailor
    icesailor Member Posts: 7,260
    Expansion Tanks also protect closed systems from "Water Hammer" due to water momentum and check valve slamming shut.
  • maybemark
    thanks ice
