Phasing Transformers
Member Posts: 4,581
Hey guys:
On the old website, there was a diagram available about phasing transformers. Is this still available? Sorry, I can't find it.
Thanks.
Alan
Thanks.
Alan
What are you trying to accomplish? A couple of minutes with a meter will keep the sparks down.0
Don't let the smoke out, or it will quit working. I heard an old plumber telling his apprentice one time that there is smoke running through the wires in a house. He said this is evidenced by looking at a local power plant. You can see them letting the excess smoke out of the smoke stacks on these plants. If you install things correctly, then the smoke does its job and disappears. If you wire it wrong, the smoke, and fire in some cases, comes out, and causes the device using the smoke, er I mean electricity, to stop working. Make sure you don't let the smoke out :-) Merry Christmas out there in California!
ME1 -
Yes! Thanks, RJ.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
