NYC Hot Water Heater - Flex Pipe OK?
BrooklynBrownstoner
Member Posts: 5
Installing a 15,000 btu replacement gas hot water heater in a 1 family building in NYC. The old installation uses rigid water and gas connections. Can I replace these with flex connections? Would make the job much easier for me and for later replacement.
Same make/model as old unit. Same dimensions.
I don't have a clue weather it is legal or not in your locale but I would pipe it in copper and if future replacement is an issue just use ball valves and unions on the piping.0
Flexible water and vent connectors/pipe are not compliant under NYC Code.
John Cataneo, NYC Licensed Master Plumber #1784Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
I think that in California, they are required because of earthquakes. But you have to strap the water heater.
In Florida, they've forgotten how to direct pipe/connect water heaters. Stainless Steel direct connects on water heaters is what you see. An inspector might be troubled if he/she saw a piped water heater. Especially if done in Type "L" Copper. Type "M" (Red) is the norm and even when underground. Or so I've seen some "Pro's" around here.0 -
In all honesty and no offence intended if you are wotking in an 8 family apt and asking that question I take it you dont have a NYC licence.How is your insurance.Ask JohnNY how hard it is to obtain the lic and everything that goes with it.In the city at least for the company I worked for we never did work for the sake of making it easier.Be careful with what you do.Again no offense intended.0
anything other than a owner occupied single family home requires a license to do plumbing & electrical work. Also, even when work other than this takes place you still need a contractor registration. Please, don't put yourself or your tenants lives at risk & hire a licensed plumber.
Also, the flex connectors are not code in NY.0 -
What gas water heater is "15,000 btu"?Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0 -
Wonder how he made out?
- 109 Chimneys & Flues
- 975 Plumbing
- 387 Solar
- 17 Recall Announcements
