federal pacific breakers
Personally, I wouldn't sleep in a house that had FPE breakers.
Do a web search about the breakers and the scandal that went with it. You won't think so highly of UL afterward.
I don't know of any "reconditioned". They didn't protect the circuit and the "stablock" design was a disaster.
You can get "listed" aftermarket replacements from most electrical supply houses.Bob Boan
Do not waste your money on replacement FP breakers. Replace the entire panel. That's the only safe thing to do. Go here for more:
http://inspectapedia.com/fpe/FPE_Stab_Lok_Hazards.htmAll Steamed Up, Inc.
Consulting1 -
Back in SoCal they were commonly referred to as "Fire Specific."0
This has come up before- here's a link to an earlier thread. The links in this one refer to the same site as mentioned above, but the URLs have changed:
http://forum.heatinghelp.com/discussion/124963/federal-pacific-electrical-panel-problems-steamhead#latestAll Steamed Up, Inc.
Consulting0 -
Every electrician I know rips them out due to fire hazards.
How do you know if you have them if there is no brand on the panel?0
If the OP is in Canada, there was no recall of FP gear, it was just the U.S., to the best of my knowledgeYou can have it good, fast or cheap. Pick two0
So, is the USA/UL recall like the Ultra-Vent/Plexco Vent fiasco? It was changed if someone was willing to eat the cost of a replacement? So no one went back and fixed their work that had the recalled venting in it?
The original installer was paid and they are LOOOOOOOONG gone. Never to be heard from again.
When I had my AC system changed, the installer needed a bigger breaker for something. He went off on a long safari to get a new breaker, After a few days, he came back with another one. So, it must be available. This being Florida, where cheap is a genetic trait, I'm surprised they didn't use WW ll war surplus panels with screw in fuses that you can reset with a penny or a dime.0 -
I remember cartridge fuses with replaceable links, I think they were 100 - 600A sizes. That was back when parts of Boston still had DC power.
3PSI gauge0 -
Follow the link I posted above- that site has pictures.icesailor said:How do you know if you have them if there is no brand on the panel?
I'm surprised anyone carries them at all, due to the liability.icesailor said:So, is the USA/UL recall like the Ultra-Vent/Plexco Vent fiasco? It was changed if someone was willing to eat the cost of a replacement? So no one went back and fixed their work that had the recalled venting in it?
Consulting0 -
I don't know if they were FP breakers. That's why I was asking about them and if you could tell.
The panel breakers don't really look like Square D Homeline breakers. There was a QO breaker outside at the compressor. They had one of those in their truck. To get the one in the panel, he had to go on Safari. It sounds like the FP's had an unusual way of connecting to the buss bar. These don't seem to have that problem. I'll have to ask the maintenance guy if he knows what they are.
Standard quickie job. Lots of latex white primer overspray in the panel when you take the cover off. If you have a problem with both eyes focusing on the same point like I do, its hard to follow the black wires. With all the white paint on the black wires. Typical high quality with my favorite electrical trick. Running 3 wire and using the red and the black for separate circuits. With two circuits in the same box. One place in the kitchen, one circuit for the DW and another for the Pig. On the same receptacle. I didn't dare to see if they made 220 volts across.
Sometimes, sparky can be right dangerous.0 -
Take a picture, and post it- if it's FP it should be obvious.All Steamed Up, Inc.
Consulting0 -
Sadly, I was in Lowes and someone mistook my camera case for a fanny pack. They stole my camera thinking it was a wallet. I didn't care about the camera so much as I did with the 4 Gig memory card with all the photos on it.
If I could figure out how to do it with my Samsung Galaxy S-4 and post it, maybe. It is the most hateful electronic device I have ever owned. Designed for me personally to drive me nuts.0 -
One of the easiest ways to ID FP breakers from others is that you push the handle towards the outside of the panel to turn them "ON" instead of towards the middle like others.
This marvel of engineering, coupled with their wedge shaped "StabLock" bus connection, causes the breaker to want to loosen from the bus when you turn it on, instead of tightening as others would.
This, of course, greatly improves the reliability of the connection - said no sane man ever.Bob Boan
Completely off topic, but I will post it anyway. Ice should write a book. They way he words things I could read it all day long and be quite entertained!0
Once watched a hundred feet of dead shorted 12/2 wire burn
and never tripped the FP breaker,they are bad news!!!!0 -
I worked in a factory that had 200A 3 phase FP panels that didn't have enough slots so they took out all the single phase breakers and replaced them with double breakers.
You could feed the heat coming off those panels from three feet away. One thing is copper wire is a lot more pliable when it's about 90C.
The real problem was putting the cover back on after replacing a breaker, stuffing all that wire back into the box without pinching one between the box and the cover. One day a guy offered to help me by holding the cover while I got the screws caught, I told him to hold the panel only and not touch the box.
He didn't listen and a live wire got pinched between the cover and the box, Jimmy flew across the hall while I stuffed that wire back somewhere where it couldn't touch anything and finished tightening down the cover. Jimmy said he never felt more alive - good thing it was 120 and not 277v.
fun times,
3PSI gauge0 -
Issue resolved. Thanks. NOT FP. The breakers switch on by pushing to the middle. Like a normal breaker. Inside on some of the breakers is a sticker that says: Sylvania. Another quality brand, sold out to the vulture capitalists for slow money.0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 994 Plumbing
- 389 Solar
