Hydro fan coil
JimRafferty
Member Posts: 21
Greetings all,
We are in the process of removing several leaking joist-mounted steam rads from the basement.
We are also removing the wooden ducting and looking to convert to a hot water boiler and hydro coils.
4 coils at about 20,000 Btu each.
Does anyone know who might manufacture a heat-only hydro fan-coil unit without A/C evap coil?
Thanks
Thanks
Try First Co. or ADP. Modine is another.Bob Boan
Try Myson if you're looking for console type0
