0-10v manifold valve actuators
Eastman
Member Posts: 1,002
Proportional thermal actuators? I always thought they should exist, now I realize they do. Has anybody used these? Suggestions, comments? What are you using for thermostats?
Heatlink up in Canada does PWM modulation of wax motor actuators.0
Are they capable of maintaining a partially open equilibrium state?0
I think so -- as long as you use their stats (and perhaps their zone boxes.) I'd give them a ring and ask.0
What is the application? The actuator for our PICV had a lot of functions and features. Might be too large for multiple valves on a manifold, howeverBob "hot rod" Rohr
hot rod, these are designed to fit on manifolds.
Check out this data sheet from Mohlenhoff on their Alpha 4 actuators.
http://www.moehlenhoff.info/getfile.php/74e295966ace19d214827c9e6b6d1fe9/8-D58-40-336_DB_AA5004_Proportional_MOE_GB.pdf
They perform a function similar to TRVs, but something's gotta provide the 0-10v signal. You could throttle flow to rads, or a floor. I'm sure one could perform a function similar to an Oventrop unibox if a 0/10v thermostat exists with air and floor warming functions in mind.
I think Spartan in Canada has a 0-10V wall thermostat available. The next concern would be that most manifolds have valves designed for on/off operation, not modulation. It takes a different shape of valve guts to provide smooth flow control vs. simple on/off. It would probably work on a basic valve, just not as well as it might if all components were meant for throttling flow.0
Yeah Jeff, I think it's probably not something that should be relied on for principle system balancing.0
Those look like they are designed to mate with a TRV body.Eastman said:Check out this data sheet from Mohlenhoff on their Alpha 4 actuators.
Viconics also has several options.JeffM said:I think Spartan in Canada has a 0-10V wall thermostat available.
Looks just like the Heat Link DDC actuator.0
