Weil Mclain HE 2 boiler not starting
Maverick723
Member Posts: 2
in Gas Heating
This is for Tim McElwain or anyone actually. I have a HE 2 boiler. I replaced the module, matter of fact this is number 2. I get a green flashing light and then 2 solid red, but the exhaust fan never starts. I wired the fan motor directly to 120 and it ran fine. I also did that and got the 3rd red light to come on. any ideas on why the fan wont start ? ? Or did I get another bad 1013-200 module ? ?
thanks Maverick723
thanks Maverick723
Here is a link to the manual. Looks pretty straight forward. One control relay through the limit contacts.
http://www.weil-mclain.com/en/multimedia-library/pdf/weil-mclain-pdf/products/discontinued/discontinued-boilers/he-boiler/he2manual.pdf0 -
I found that relay online and will replace it. Thanks for the input ! Its been quite a process of elimination. Learning a ton about my furnace. I will post my results and other things I tried in the process of elimination !
thank you !
Maverick7230 -
I have this same problem. LEDs indicate "limit circuit closed".
the blower motor never starts. Green LED blinks 10x then 2 red.
??0 -
Does anyone know what relay that is?, Is it the high limit switch?0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
