Should return side vents in my 2-pipe system ever close?
DuggieFresh5
Member Posts: 48
Intuitively, I don't think those vents should ever close because only condensate will be in that line. The reality is that they do close during a long burn. Are my expectations out of line?
You might have a bad trap somewhere, if the returns are getting hot enough to close the vents.All Steamed Up, Inc.
Consulting0 -
Do you know what kind of 2-pipe system you have? Are their traps on the radiators, or keyed valves on the outlet. Or, some other type of fitting.Dave in Quad Cities, America
http://grandviewdavenport.com1 -
The radiators all have traps. I know there was steam getting into the returns and Gerry Gill installed a trap on a radiator we found without one.
It sounds like I need to determine if one of my traps failed...0 -
With that new trap, the steam can no longer reach the returns from that point so it will find its way thru any traps that are leaking.
If Gerry's working on this, you can't do any better. He'll get you straightened out.All Steamed Up, Inc.
Consulting5 -
Thanks Steamhead. I dropped Gerry a line to ask for more help.0
