Should return side vents in my 2-pipe system ever close?
Intuitively, I don't think those vents should ever close because only condensate will be in that line. The reality is that they do close during a long burn. Are my expectations out of line?
    Steamhead Member Posts: 18,197
    You might have a bad trap somewhere, if the returns are getting hot enough to close the vents.
    Consulting
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    Do you know what kind of 2-pipe system you have? Are their traps on the radiators, or keyed valves on the outlet. Or, some other type of fitting.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
    frankii
  • DuggieFresh5
    DuggieFresh5 Member Posts: 48
    The radiators all have traps. I know there was steam getting into the returns and Gerry Gill installed a trap on a radiator we found without one.
    It sounds like I need to determine if one of my traps failed...
  • DuggieFresh5
    Thanks Steamhead. I dropped Gerry a line to ask for more help.
