Wi fi T-stat ?
Danscrew
Member Posts: 130
Looking for a WI FI T-Stat that you can see run times for the boiler? (usage) Who is leading the way in the market for the best ? I like the Honeywell's with the Outside air Temp showing on the screen. Don't want a nest. thanks Dan
As far as I researched last year, none of the wi-fi Honwell Tstats have that function. I can't understand why they dropped that function. We discussedthe issues here:
http://forum.heatinghelp.com/discussion/152167/honeywell-wifi-tstat-problems-any-solutionTwo-pipe Trane vaporvacuum system; 1466 edr
Mike
Thanks i will check them out I have not seen any that gets my attention.0 -
John
Thanks I started looking at them looks good a little pricey? Where can you get one for the best price? Thanks Dan0
- 109 Chimneys & Flues
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
