Wi fi T-stat ?
Danscrew
Member Posts: 130
Looking for a WI FI T-Stat that you can see run times for the boiler? (usage) Who is leading the way in the market for the best ? I like the Honeywell's with the Outside air Temp showing on the screen. Don't want a nest. thanks Dan
As far as I researched last year, none of the wi-fi Honwell Tstats have that function. I can't understand why they dropped that function. We discussedthe issues here:
http://forum.heatinghelp.com/discussion/152167/honeywell-wifi-tstat-problems-any-solutionTwo-pipe Trane vaporvacuum system; 1466 edr
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF0 -
Mike
Thanks i will check them out I have not seen any that gets my attention.0 -
John
Thanks I started looking at them looks good a little pricey? Where can you get one for the best price? Thanks Dan0
- 86.9K THE MAIN WALL
- 57 Biomass
- 110 Chimneys & Flues
- 5.7K Gas Heating
- 106 Geothermal
- 70 Pipe Deterioration
- 978 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
