Wi fi T-stat ?
Danscrew
Danscrew Member Posts: 130
Looking for a WI FI T-Stat that you can see run times for the boiler? (usage) Who is leading the way in the market for the best ? I like the Honeywell's with the Outside air Temp showing on the screen. Don't want a nest. thanks Dan
  • vaporvac
    vaporvac Member Posts: 1,520
    As far as I researched last year, none of the wi-fi Honwell Tstats have that function. I can't understand why they dropped that function. We discussedthe issues here:
    http://forum.heatinghelp.com/discussion/152167/honeywell-wifi-tstat-problems-any-solution
  • Limamikemike
    Limamikemike Member Posts: 28
    Take a look at Ecobee, once registered the you get access to their online portal with all sorts of information about the area the stat is installed, including month to month run time that can be adjusted to read per degree day.
    Danscrew
  • Danscrew
    Mike
    Thanks i will check them out I have not seen any that gets my attention.
  • John Mills_5
    John Mills_5 Member Posts: 952
    See the newest Ecobee3?
    Honeywell is really lacking in what they tell you online.
    Danscrew
  • Danscrew
    John
    Thanks I started looking at them looks good a little pricey? Where can you get one for the best price? Thanks Dan
