Leaking Radiator....Replace, Repair, or Ignore???
AdmiralYoda
Member Posts: 758
I've been inspecting my single pipe steam system lately and have been nit-picking all the things wrong with it. One of my radiators has leaked since we bought the house 7 years ago. It doesn't leak condensate, just steam. Its not a huge air leak but enough that you can hear it during normal operation.
When the boiler is really working hard and gets to its cut out pressure (1.25psi) it is more noticeable.
My question is.....what is the best thing to do? New radiators are too expensive, used ones are hit or miss, and repairing it may open up a can of worms.
Would ignoring it waste tons of money? Or am I just over thinking the whole thing? Thanks!
can you post a picture of the radiator and the specific area where the leak is?
3PSI gauge0 -
I agree with Bob post a picture, but in general leaks are very bad on steam systems.0
I'm at work so it will have to wait a little bit but I will try and describe it. The leak is between two of the sections of the radiator. Specifically it is at bottom where the condensate drains through the sections. The spot that is leaking is at the top of the condensate drain, so only air is leaking and not water (thankfully).0
If it's leaking while running that is steam...remember real steam is technically invisible. When you think you are seeing "steam" (pot boiling) that is water vapor. What could be happening is the steam is condensing on the hot radiator and then immediately evaporating so you never see any water or it's just being absorbed into the air immediately. How much make up water does your boiler take on? That is what will be the issue the make up water kills the boiler if it is excessive.0
As a result of this leak, are you having to add water to the boiler frequently? Too much fresh water is a boiler killer!--NBC0
Well I have a feeling I'm about to open up a whole new can of worms. Its been a while since we ran the steam system 100% of the time since we've been supplementing with our wood stove.
But when we did run 100% steam. During the colder weather I was adding water once per week.0 -
I'd been able to repair leaking radiators with JB Weld. It takes quite a bit of work tho to ensure that you've properly cleaned the cast iron to ensure good sealing of the epoxy to the radiator.0
If you needed to add water weekly that is excessive. There are people that might only add water once a year and typically only more than that because of blow downs and system maintenance.0
Post a picture of the radiator. Maybe all that's needed is a new push-nipple.All Steamed Up, Inc.
Consulting0
- 116 Geothermal
- 15.8K Strictly Steam
- 52 Industry Classes
