Problem with a mixing valve
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,686
This discussion was created from comments split from: troubleshooting a mixing valve.
Retired and loving it.
  • cevhh
    cevhh Member Posts: 3
    I seem to have same/related issue... since I thought I had scale issues... I just went ahead and put a BRAND NEW 1"dia Honeywell AM-1 70F-140F low lead mixing valve in.
    With the Valve set at 140F, the hottest I can get off of it is about 80F when the tank water leading to it is at 120F. I boosted up the hot water tank to 150F and in turn it raised upabout 100F.
    Note that I use my Hot Water Tank both for domestic hot water AND I run a separate recircuation line off it it thru a Heat Exchanger to heat my house with radiant. System works well although I believe running the hot water tank at !50F makes the tank scale up so I was attempting to run it a little cooler this heating season.
    I had heard that it was common that the AM-1 is defective from the factory in many instances...
    Any help / coaching would be greatly appreciated!
    w/r
    Ev
