Riello hydraulic jack ...
rhowe33
Member Posts: 6
Hello, I am a certified OBM, that being said I'm very proficient with most burners but only familiar with Riello Burners. I have one on a well mac-lain gold series that has a hydraulic jack with no fixed air gate...I think its an older model burner. I didn't look at the model of it. Anyways, the jack has gone to opening full tilt from being completely closed and now the flame is running a bit too lean.
My question is, is the hydraulic jack messed up, because it wasn't doing this a few days ago, it was working correctly. Is there a way to adjust these? I tried playing with the nuts on the arm of the jack to no avail. Is it the pump sending to much oil to the jack? I didn't get a pressure reading on the pump.
I'd be very appreciative for any help from anyone who might know what's going on here.
Ron
Ron
Yeah I know that's how it works on the newer burners however, this burner has no adjustment under the damper whatsoever. I think it's a fairly old model burner that was put onto this newer boiler.0
The jack is your air intake adjustment on those. There is a # scale on the housing. Is the jack leaking?
Thank you bill, that pdf file is most useful. The jack only leaked a bit when nut B was loosened, when tightened it didn't leak at all.
RJ- Thanks for the info, I work in an extremely isolated community in the south arctic in Canada, I'll probably have to create a delete kit using other spare Riello burners we have lying around.0 -
You're welcome, and best of luck
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
