how to find Btu for gm delco heat steam bioler model# DB 3 S.
j70b
Member Posts: 2
I second that. Are you putting an all new heating system in? You say no radiators? If you need to size a new system you need to do a complete room by room heat loss calculation you can't depend on what the old boiler was...most likely it was way over sized.SWEI said:
What are you trying to accomplish?1 -
I had one of those for 26 years, mine was a 5 section 140,000 BTU unit. If you take a side off you can count the sections.
If you don't have radiators to feed you might as well start with a heat loss so you will know what you need to heat the house.
3PSI gauge1 -
You could probably get a good idea of the EDR by measuring the distance between where the pipe(s) came up through the floor, subtract three inches for valve(s), look at the paint on the wall and add about three inches for how deep the paint brush went behind the radiators and then look at the indentions in the floor and then look up the EDR of the rads. It's that simple! (or you could just do a room by room heat loss)
