TRV to fit here?
Harvey Ramer
Member Posts: 2,281
a double angle valve like this? Lh or Rh versions available.Bob "hot rod" Rohr
@Hot Rod Do you have some dimensions or different pic angles? From here it looks like a reg, 90° turn on that valve.
Thanks
Harvey0 -
You are dealing with both a 90 degree turn and a change in height. You will either have to adjust for the height by cutting the supply pipe coming out of the floor and using fittings to bring that underneath the typical angle valve. Or, lpositon a standard angle valve horizontally and adjust the supply height to feed into it at the correct height. In either case, you will probably have to cut and re-thread the supply pipe coming out of the floor. Know the various dimensions should determine how to proceed.0
Thanks Rob. It doesn't look like any of those will work. I need 1" with a high CV and I didn't see any config. that would eliminate piping changes.
It's on a converted gravity system. I don't want to rock the boat to much. I guess I should extend the riser coming through the floor and use a high capacity horizontal angle valve. That would eliminate 1 90° bend which should help compensate for the pressure drop through the valve.
Harvey0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
