I now have a hole in the main line pipe...
Jessie
Member Posts: 6
Today I went to replace the air vent on the main line that was leaking steam. Off of the main line elbow joint heading up to the first floor was a small elbow joint leading to the vent. The small elbow was at an angle, so the vent was at an angle. It seemed like a good idea to straighten these. A little brute force and I tore the small elbow right off. Turns out, a previous owner added a vent by tapping the main line and screwing in an elbow joint. Now I have a 1/4" hole in the main line with half of the small elbow threads still in there. My questions is, do I really need a vent there? The main floor has two radiators only a few feet from this spot. Clearly there was not a vent there to begin with. Do I weld a patch over the hole and call it a day? Weld a new elbow joint on and add a vent? Tap a bigger hole in and screw in a new elbow joint?
How long is the main, and what pipe size?All Steamed Up, Inc.
Consulting0 -
A picture is worth 1000 words. Post a couple pictures of your situation and it will be much easier to help you out. One thing I can tell you, you need main vents.0
Half the threads are in my hand, half are in that hole.
Without measuring, I'm guessing it's about a 3" pipe and 18-20'.0 -
Looks like 2" pipe. That's not an ideal spot for a main vent anyway, it should be about 15" from the end of the main run or at the drip were the dry return drips to the wet return.
You could try to use an extractor but it look pretty corroded, how far back is your nearest union??DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Looks like you may have enough surface to drill and tap a 3/8" bushing in there. Attach a magnet to the elbow so it might grab some of the shavings. Good luck0
I would keep the same size hole and just re-tap it.0
We'll need a better idea of where that vent is on your system. From the picture it looks like that's a branch line from the main that feeds the two radiators you mentioned.
If so, is this line appreciably longer than the other branch lines?
If not, does the main line slope down from the boiler and drain into a return line?All Steamed Up, Inc.
Consulting0
- 109 Chimneys & Flues
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
