90 degree turn or two 45 degree turns
heatingFun
heatingFun Member Posts: 84
edited October 2014 in THE MAIN WALL
For the water heating main pipe, there are many (more than 10) 90 degree turns (turn left\right and turn up and down). I am wondering does it worth to use two 45 turn elbows instead of just one 90 degree elbow?
  • Jack
    Jack Member Posts: 1,050
    It is always better to use 45, if the space permits. Half the pressure drop and if you can lay it out correctly, it makes it look like a mechanic did the work. Well, at least that is the way I see it.
    Basic lay-out for 45's is C-C X 1.414- make in. Now that I've put that out may the floodgates open with more advanced lay-out info.
  • icesailor
    icesailor Member Posts: 7,260
    You mean, "The Square Root of Two?
