Retrofit gas power burners.
airhead
airhead Member Posts: 9
I have had several inquiries from residential customers looking to convert from oil and install power gas burners. I would like to hear peoples thoughts about this. I have not been able to get feedback if it is a worthwhile investment. Are there any reasons not to consider this. Thanks
  • Tim McElwain
    Tim McElwain Member Posts: 4,655
    Have you installed gas conversion burners in the past? If not make sure you get some training before attempting to do a conversion
    Depending on the age of the equipment a gas power conversion burner can be a good choice to replace the oil burner. My present cut-off is 10 to 12 years old. Anything over that depends on equipment condition.
    I have over the years done over 3,000 conversion burner installs so I am obviously going to say it is a good investment.
    You will if properly set up be able to equal the combustion efficiency of the oil or even properly set up exceed the oil efficiency.
    Steamhead Member Posts: 17,885
    I'm with Tim, though I haven't installed over 3,000 of these burners ;) Still, my results are as good as his.
    Consulting
