HW S8610U ignitor control
Techman
Techman Member Posts: 2,143
In the green LED Status Code section , what does 9 blinks mean? Its not in the chart.
  • Tim McElwain
    Tim McElwain Member Posts: 4,659
    I assume this is on the new S8610U - 3009 (black case)? Is it the modified version which has just one diagnostic light? The modified version has test points for taking microamps. I do not have my diagnostic codes handy they are at the training center. I will check tomorrow and get back to you.
  • Techman
    Tim, yes it is a black case,w/ one light.The fault codes go from 1-8. Thank You.
  • Tim McElwain
    You are correct there is only 8 flash codes. What is it doing as far as operating? You might try contacting Honeywell for assistance.
  • Techman
    Hi Timmy, I called HW and they said that 9 blinks is a "everything is normal" indicator. Its an indicator of the flame current from the pilot flame. Tks .
