Propress for pex
STEAM DOCTOR
Member Posts: 2,513
Does anyone have any experience using the Propress on pex tubing? Any pros, cons, limits in types of tubing, effects on flow rates,pressure drops, etc etc.
Thanks
Thanks
If you mean the stainless viega crimp rings, they work well. Downside is you need good access to get tool/jaw on, but they are very durable.0
Can the viega press fittings be used on all brands of pex or just viega pex?
Thank you.0 -
I've seen mix and matches but personally I stick to proprietary matches. Just a liability thing.0
