Which way to pump
americanpacemaker
Member Posts: 1
in Oil Heating
I am installing a hot water boiler with a primary / secondary plumbing system. The boiler is plumbed as a secondary into the primary pipe. Should I install the pump for the boiler pumping into the return on the boiler or on the supply pipe into the primary pipe ?
- 120 Geothermal
