Which way to pump
I am installing a hot water boiler with a primary / secondary plumbing system. The boiler is plumbed as a secondary into the primary pipe. Should I install the pump for the boiler pumping into the return on the boiler or on the supply pipe into the primary pipe ?
    hot_rod Member Posts: 27,850
    pump into the boiler, away from the expansion tank connection. This assures the boiler sees the additional pump head when it starts.
    RobG
