Steam fittings
Shemp
Member Posts: 45
I am trying to install an old steam rad that was disconnected a few years back.
The pipe was capped off.
The original fittings and valve are gone.
Just wondering, can I use regular brass threaded ball valves? The kind that you get from home depot ?
Thanks.
Thanks.
Use a radiator valve
Why wouldn't you use a radiator valve?
http://www.supplyhouse.com/Radiator-Valves-6260000 -
Thanks for all your help. Unfortunately its very difficult to get parts for one pipe steam where I am but I did manage to get the rad hooked up and working.
Thanks again!0
- 87K THE MAIN WALL
- 111 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
