Routing pex
hotfoot
hotfoot Member Posts: 19
Quick question, can I run the return line of pex under the baseboard? Is there any heat or other issue that can arise? Thank you.
  • icesailor
    icesailor Member Posts: 7,260
    PEX Returns:
    If you are using PEX to run hot water UP to the unit/element, it certainly isn't going to be hotter going BACK from the element. Personally, I'd be running over the top of the element. Its designed to be done that way. There's not a lot of room when you go under the element and it might restrict the air flow through the heater.
  • Gordy
    Gordy Member Posts: 9,546
    More specific
    Do you mean actually under the base board assembly.
    If so be careful of blocking the intake of the base board. I think heat will be an issue the return water temp is high it will effect convection .
    Remember base board relies on cold air sucked in from the bottom to be heated. Once you narrow that delta I think air flow will slow down
    hot_rod Member Posts: 27,045
    edited September 2014
    tough to suspend
    pex tube in an enclosure. If you go that route, use the straight lengths of pex or Viega FostaPex.
    Some BB brands have provisions to place the return above the element, it would be easier to mount and keep it on top. I suspect it will have a small heat output penalty, blocking the convection flow.
    SlantFin installation guide #30 style
  • hotfoot
    Raising baseboards
    These baseboards are located in a basement and appearance is not a concern. If I run the return above the fins it would have to cross the in and out to the base board on both ends. Would it be ok if I raised the baseboard 1" (1" being the height of the pex) off the ground? That way I can run the upper pex to feed the baseboards and than loop under and return the pex without all the elbows and still giving the proper amount of cool air under the baseboard. Thank you
